I'm trying to implement reports in Venapp. I'll Probably make a mistake somewhere, but I get the message that Vensim is unable to find the specified tool. I tried a simple text, but even that failed.
The next problem is I tried to display the reports in Vensim itself, but there every variable I try to input is replaced by a "1" and I get the complete program-code displayed with the following error:
" Got 23 but expected 0 variable descriptors"
Can Somebody please Explain what I'm doing wrong. I attached the vgd file, cause I think the problem is in there.
Thanks Jeroen
Reports In Venapp
Reports In Venapp
- MBG.vgd
- (2.08 KiB) Downloaded 609 times
The last problem was solved by putting the variable names inbetween the brackets (\ /) instead of using empty brackets and putting the variable names underneath it using Var: ---. Still it bugs me that the Manual suggests both options shouldn't pose a problem.
But I do have a new question, how to arrange the outlining of the numbers/variable values. I want them in line when I export it to a word file.
Jeroen
Jeroen
Thanks a lot. I solved in an other way. I'm now exporting to excel, this way I can use a tab delimited file.
Now I'm only left with the problem of getting my reports recognised by Venapp.
I use "Command,,,,,,,,,,"Special>Readcostum|mbg.vgd" and "Tool,"RP1",,,,,,,,,"Costum>Month",
I'm using my model in a gaming situation, I studied the examples, but can't figure out what goes wrong (The examples work fine). In Vensim itself every report also functions as it is supposed to be.
Jeroen
Jeroen
It was a typing error in the message.
I have tried to implement my Graph-file in one of the samples, this didn't work. When I restored the old links, Venapp even refused to recognize these, giving the same error. "Unable to match the name .... to a user tool. "
Could it be anything with binary/non binary files. The model is in vmf, and I've tried both vgd and vgf for the graph file. Venapp is still in Vcd, but I have tried vcf once, didn't solve the problem, just created more of them.
I don't have sable, so haven't tried it.
[Edited on 17-3-2004 by Pruyn]
