How to map one variable to another variable?
husnafezaahmad
Post by husnafezaahmad »
Hello there! :D
I have this one question regarding on the model that i'm currently working with.
I have 2 variables; sorted marginal cost and sorted generation as show in figure below.
Screen Shot 2020-10-09 at 23.36.57.png (218.94 KiB) Viewed 3906 times
These two variables are mapped under the same subscript and both are actually correlate. But my problem is, how do i arrange these two variables that can give me an output like this;
Screen Shot 2020-10-09 at 23.46.39.png (238.5 KiB) Viewed 3906 times
Is it possible to do so?
Re: How to map one variable to another variable?
Can you upload the model? I'm sure it's possible, but we don't have enough information to help.
Maybe vector elm map function is what you need?
You can use vector elm map to pick elements out from another subscripted parameter.
husnafezaahmad
Administrator wrote: Fri Oct 09, 2020 3:56 pm Can you upload the model? I'm sure it's possible, but we don't have enough information to help.
Here it is :D
It's on the MARGINAL COST's view.
Initial One.mdl
(55.21 KiB) Downloaded 202 times
husnafezaahmad
Administrator wrote: Fri Oct 09, 2020 3:57 pm Maybe vector elm map function is what you need?
I tried using VECTOR ELM MAP as suggested, but it seems it didn't work (or maybe i used it wrong?)
husnafezaahmad
Anyone can please help me? :'(
I'm not sure I understand what you need to do. Are you asking how to generate an Excel sheet with the parameters as you have them in your sheet?
If the requirement is a table that interleaves marginal cost and generation, as in your example, I don't think there's a way to do that within Vensim.
husnafezaahmad
tomfid wrote: Mon Oct 12, 2020 3:32 pm If the requirement is a table that interleaves marginal cost and generation, as in your example, I don't think there's a way to do that within Vensim.
Oh really? It's okay then.Thanks a lot Tom & Admin :)
