I have a model with several subscripted variables in GAME mode. In V9, set to the old sketch mode, these variables work as usual when the model is run, showing a panel to edit the variable for each subscript element. But if I change to the new sketch mode, only the first subscript element is offered for editing. The attached composite image might show what I mean more clearly. Perhaps I'm simply missing an obvious step, but I can't see anything in the help file.
This is not an urgent problem as I can simply run the model in the old sketch view.
Best regards,
Phill
Subscripts in GAME mode in new sketch interface
- Subscript_query.png (35.39 KiB) Viewed 2133 times
Re: Subscripts in GAME mode in new sketch interface
Working on it now.
