Export to SVG
Paul Ader
Export to SVG
Post by Paul Ader »
I am having a problem with the new Export Sketch to SVG functionality in Vensim version 9.2 and would appreciate your help.
1. I opened the attached .MDL file in Vensim PLE Version 9.2.1 x64 Build TK-220303.00128
  • The software was downloaded on a trial basis
  • The .MDL file was created by a senior research associate at the National Institute for Health Research Applied Research Collaboration West based at University Hospitals Bristol NHS Foundation Trust using a fully licensed version of the software.
  • The work was carried out for a Ripple Effects Mapping project at Active Gloucester and I have their permission to share the model with you.
2. I made sure that the whole model was displayed on the screen and then used the Export as SVG option from the View menu.
3. When I opened the attached SVG file in Inkscape, I could not see anything (the same happened when opening the SVG file in Chrome). To make the SVG visible, I had to select an object and zoom into it (at 25,381% for an arrowhead!) and then bring the zoom back to 200%. This allowed me to see the image shown below. As you can see the SVG file has created a narrow line-wrapped version of the text for each element in the Vensim model, has used a relatively large font, and, as highlighted by the use of different colours on one of the elements below, has put each wrapped line into a separate text box. The separation of each line into a separate text box makes it very difficult/time-consuming to work with the data in SVG.
Could you let me know if there is a way around this problem?
Thank you
Kind regards
Paul
This is an extract from what I see when I open the SVG file
GlosREM2.zip
This is a zipped version of the SVG file created by Export to SVG
(66.67 KiB) Downloaded 195 times
REM Output - FINAL ANONYMISED.mdl
This is the original model that I want to see in an SVG format
(75.58 KiB) Downloaded 176 times
EwoutH
Re: Export to SVG
Post by EwoutH »
Might be related to viewtopic.php?f=2&t=7881
Paul Ader
Re: Export to SVG
Post by Paul Ader »
Thanks for the link. I had seen the "Embed text in SVG" post and could not see a direct connection between the issues. If you can see the connection, please let me know. Cheers.
Re: Export to SVG
I'll have to raise this as a bug for further exploration.
Re: Export to SVG
For now, you can still copy/paste as a bitmap if you need to.
Paul Ader
Re: Export to SVG
Post by Paul Ader »
Hi. Has this been raised as a bug? If so, do you know when it might be addressed? The reason I ask is copying the sketch and pasting it as a bitmap creates an image that is unreadable. I look forward to an update. Thanks
Re: Export to SVG
It has been raised as a bug. The underlying framework we use for Vensim is responsible for the SVG creation, so we are a little stuck until it is addressed.
