Installation Error Code 977
xianjia xu
Post by xianjia xu »
Hi! I would like to using Vensim PLE, but I can't install successfully after downloading the Installation package. The error statement is the following:
“Resource file comes from a different version of Vensim(002)”
"Reinstall Vensim(error 977)"
My Installation info:
System: Window 11 x64
System Language: Chinese
Installation path: default
Usage: Academic use, very first time installation
Appreciate your support!
Re: Installation Error Code 977
Did you install using administrative permissions?
xianjia xu
Yes,I did.
In C:\Users\Public\Vensim\PLE, there should be a file named en09020400.vrf, can you zip this and upload it to the forum please?
xianjia xu
ok
en09020400.zip
(207.2 KiB) Downloaded 151 times
The attached should work for you.
I'll need to get hold of a computer with Chinese as the operating system to test why this is happening.
en09020400.zip
(192.61 KiB) Downloaded 175 times
Miracle
Post by Miracle »
Hi, I have exactly the same situation, could you please help me out?
I attached the document in users/public/vensim, en09030200, don't know if that is what you need. But I am in a urgent of getting my assignment start. I hope this can be solved in a way. Thanks very much
en09030200.zip
(209.04 KiB) Downloaded 119 times
Miracle
Post by Miracle »
Administrator wrote: Thu May 19, 2022 12:54 pm The attached should work for you.
en09030200.zip
(209.04 KiB) Downloaded 100 times
Can you try the attached file?
en09030200.zip
(194.61 KiB) Downloaded 130 times
Miracle
Post by Miracle »
Administrator wrote: Mon Aug 15, 2022 6:10 am Can you try the attached file?
Awesome!!!! Thanks very much!!
lvjunfeng
Post by lvjunfeng »
I had same problem with Vensim Model Reader, I used the file from the current post but it didn't work
Can you let me know what language your computer is in please? I've set up a Chinese (simplified) machine here and Vensim installed without any problems.
lvjunfeng
Post by lvjunfeng »
My problem has been solved, thank you for your reply
Liyan_Scarlett
Post by Liyan_Scarlett »
Hi! I met the same situation as well,but I attached the document in users/public/vensim/PLE,just has en09030300.vrf,could you please help me check this file? Cause I am urgent to get my assignment start.I hope it can be solved as early as possible.Thank you very much!
en09030300.zip
(207.15 KiB) Downloaded 87 times
Liyan_Scarlett
Please start a new thread and provide some more information (such as operating system etc).
xushuyu777
Post by xushuyu777 »
Hi! I met the same situation as well,but I attached the document in users/public/vensim/PLE,just has en09030400.vrf,could you please help me check this file? Cause I am urgent to get my assignment start.I hope it can be solved as early as possible.Thank you very much!
xushuyu777
Administrator wrote: Tue Sep 27, 2022 5:31 pm Please start a new thread and provide some more information (such as operating system etc).
If you are running Windows, make sure you install Vensim as an administrator. Right click on the Vensim installer and select "Run as administrator".
If you still have trouble, please start a new thread and provide some information so we can help you.
xushuyu777
Administrator wrote: Wed Sep 28, 2022 7:42 am If you are running Windows, make sure you install Vensim as an administrator. Right click on the Vensim installer and select "Run as administrator".
I'm sure that I install Vensim as an administrator.
In C:\Users\Public\Vensim\PLE, there should be a file named en09030400.vrf, can you zip this and upload it to the forum please?
