Adding 2 'Fixed delay' functions in one equation
nahsan
Vensim version: PLE+
Post by nahsan »
I am trying to add 2 fixed delay functions in one equation.
Example: DELAY FIXED( supply of new items*, lifetime of new items, 0) + DELAY FIXED(supply of old items, lifetime of old items, 0)
It shows error of 'info beyond the final closing) - check for an extra)'
Although I have tried to fix but error stays same.
Please guide.
nahsan
Re: Adding 2 'Fixed delay' functions in one equation
Post by nahsan »
please ignore the multiply sign in the equation. It was a typo. I still need help in this
You cannot add two DELAY functions together (and it's better practice to separate them anyway, it makes debugging a model easier).
The help system does state that DELAY FIXED should directly follow the equals sign
https://www.vensim.com/documentation/fn ... elay+fixed
Create two variables and add them
new items expiring = DELAY FIXED( supply of new items, lifetime of new items, 0)
old items expiring = DELAY FIXED(supply of old items, lifetime of old items, 0)
total items expiring = new items expiring + old items expiring
In many cases, aggregation of diverse items makes the pipeline DELAY FIXED unrealistic, because items will vary in their lifetimes. In that case it may be better to use a lower order delay, like DELAY3, which also doesn't have the RHS constraint.
