I'm trying to open my simulation in other device, but all variable was overlap and I need to klick one by one to fix it. Is there any way to Fix it instantly?
Thank you.
Overlap Variable in Different Device
- Test.PNG (5.79 KiB) Viewed 1451 times
Re: Overlap Variable in Different Device
I'm guessing you've used a font on your own machine that is not available on the other device.
The latest version of Vensim includes fonts that can be used (all called "Vensim...."). You can use these, or make sure you use something like Times New Roman or Courier.
There is also a menu option View->Size all clear boxes to content.
