I'd be grateful for links to past posts or direct advice.
1. I am working in Vensim Pro and have a model with 3 dimensions - Age, Operation, Health Trust. This comes to nearly 7000 specific dimensions in my model. Please don't comment on the appropriateness of these categories, it will eventually be a SD model theoretically, in terms of stocks and flows and feedbacks; just need the dimensions for client purposes as well.
2. I'm antiquated
3. This GET XLS DATA is both for timeseries data, but it is actually important that I can choose a base year for different scenarios. The GET DATA AT TIME function crashes in particular when I tried to just get various base years out of the timeseries.
4. Even more humiliating, to import the data, I have 60 equations in one variable because I only know how to import this way (via the old .xls not even .xlsx)..... the first subscript is the 'master' and then i need to write new equations for each other pair of subscripts. Obviously I made 'age' the first subscript, or it would have been a lot more equations (age has the most elements).
5. Typically, I would run this model to import the data, and then save the .vdf file and create a new model for the real work. But I seem to be maxing out the potential of this method, and would love a cleaner way to import data as arrayed by my data scientist. CSV? How would it be formatted?
6. I do use .cin files for changing model constants and parameters. Just saying.
Any help much appreciated. Basically, I need to import a lot of data, and then it's a simple SD model, but with 7000 unique dimensions and (hopefully, eventually) calibrated to an imported timeseries so that I can initiate the model in equilibrium and then run scenarios where I disturb the equilibrium.
Thank you,
Sarah
