Hi All,
I would like to normalize a variable output from 0 to 1. The formula for this is normalized_var = (var - min_var) / (max_var - min_var)
How do I implement this in DSS? The subscript protocol is not entirely clear to me for iterating. MIN and MAX take two variables and their use is not appropriate in this case.
I found very little on the forum about this, but it is a pretty standard operation. Perhaps I missed something. I just need to know the implementation formulas in Vensim DSS.
Normalizing Variables
Re: Normalizing Variables
I think we need more info.
When you mention min_var and max_var, are you referring to the min/max of a variable over the entire simulation?
The following is perfectly valid Vensim syntax, so I'm not sure why it's troublesome to just use this.
The problem is that there is no way to search for the min and max, from what I can see in the documentation. If someone could provide the built-in formula for how to find the min and max of a variable output, then I could use the equation.
Thank you!
Thank you!
You use MIN or MAX
https://www.vensim.com/documentation/fn_min.html
https://www.vensim.com/documentation/fn_max.html
Interesting. The MIN(A, B) must be MIN(self1,self1) for that to work. The “minimum of two alternatives.” That is a bit of nonsense but I can guess and check.
I'm very confused by this thread.
If you want the min/max during a simulation, you can use those two functions.
If you want the min/max once a simulation has ended, the stats tool will give you these.
Does this solve the problem?
