Normalizing Variables
geo_curious
Post by geo_curious »
Hi All,
I would like to normalize a variable output from 0 to 1. The formula for this is normalized_var = (var - min_var) / (max_var - min_var)
How do I implement this in DSS? The subscript protocol is not entirely clear to me for iterating. MIN and MAX take two variables and their use is not appropriate in this case.
I found very little on the forum about this, but it is a pretty standard operation. Perhaps I missed something. I just need to know the implementation formulas in Vensim DSS.
Re: Normalizing Variables
I think we need more info.
When you mention min_var and max_var, are you referring to the min/max of a variable over the entire simulation?
The following is perfectly valid Vensim syntax, so I'm not sure why it's troublesome to just use this.
geo_curious
The problem is that there is no way to search for the min and max, from what I can see in the documentation. If someone could provide the built-in formula for how to find the min and max of a variable output, then I could use the equation.
Thank you!
geo_curious
Interesting. The MIN(A, B) must be MIN(self1,self1) for that to work. The “minimum of two alternatives.” That is a bit of nonsense but I can guess and check.
I'm very confused by this thread.
If you want the min/max during a simulation, you can use those two functions.
If you want the min/max once a simulation has ended, the stats tool will give you these.
Does this solve the problem?
