BUG Find Again no longer working
skuk
Post by skuk »
In DSS 9.4.0 x64 on widows 11
The find again function does not work. With Move Tool selected, highlighting a variable then pressing F3 or selecting find again from the edit menu used to find other instances of that variable, or if there were none return "not found in any other view" or something like that. Now nothing happens at all. F3 with no variable selected still opens the search dialog. But even after using that repeated pressing F3 or using the edit menu item does nothing.
I believe it worked for me before recent update, not sure how long ago but as I use this frequently it probably was only hte most recent update.
Re: BUG Find Again no longer working
9.4.1 is available for download, it should have this fixed.
skuk
Post by skuk »
Thank you, works as before now
