PULSE TRAIN simulation stops after 24 periods
I tried to get the PULSE TRAIN function to run a simulation beyond 24 periods but couldn't get it to work. Would someone please suggest how to make this work, if possible or have alternatives to this function?
Re: PULSE TRAIN simulation stops after 24 periods
Can you upload the model you are trying to do this in?
Sight unseen, the only obvious cause for this would be that the end time is set < FINAL TIME.
You might check the sample model in the Help system.
Sorted, thank you.
