Exporting large sensitivity output
sibel
Post by sibel »
Hi, I am trying to export 2+ GB sensitivity output file to csv using Model->Export Dataset command on DSS 9.3.5 but I can't. Vensim simply stops responding. Any other way I can do this?
Re: Exporting large sensitivity output
You could use a savelist or SAVEPER to reduce the scale of the data.
You could also try the relational Data List format or .dat (though the latter is not really friendly to other apps). Both will be large.
.tab is probobly no better, and .xls is surely worse.
It probably hasn't stopped responding, it will just take a while.
