Save and Recal Slider Settings
- Vensim version: PLE+
I am using PLE+ and conducting experiments by evaluating combinations of variables at different values and running a simulation on each change. Is there a way to save the settings so I can recall the combination? For example, if I have 10 sliders and want to set them at high, med, and low values, and save the settings so I can repeat the experiment. I know ho to save the results. But how do I save and recall the variable settings?
Re: Save and Recal Slider Settings
That is one of the limitations of PLE+, you cannot load/save CIN files (which contain constants).
There are two things you can do.
1. Export the dataset, and then find the constants in the resulting text file (they will have only one value) and copy those back into the model.
2. Click on the constant you changed, view the table of values for it, and copy the value back to the constant.
