Coustom grafics get lost
stebue
Post by stebue »
We use Vensim PLE, 10.0. After saving a model and reopen it, the coustum grafics are lost. You can see the grey areas, where they have been. But the definition doesnt exist anymoren. This has happend several times to a lot of students.
Re: Coustom grafics get lost
Can you upload a sample model?
stebue
Post by stebue »
I will try. I made the grafics new, so I now it is ok. I will send an example, if it occurs again. 16 of 19 students had the issue, but they all fixed it.
If you can give step by step instructions of what you do, we can try and do the same.
If you are doing an exercise that someone has given you, if you can share that, I can run through it myself to see why the graphs are lost.
You can email it to vensim@vensim.com
stebue
Post by stebue »
Here is an example. I made this simulation on Wednesday. As a open it today, there is a grey area only. The defintion of the custom graphs is lost.
Screenshot 2023-11-10 085706.png (13.11 KiB) Viewed 8666 times
Screenshot 2023-11-10 085808.png (18.81 KiB) Viewed 8666 times
Wagen zwischen zwei Federn.mdl
(3.17 KiB) Downloaded 606 times
I think this is already ticketed - it's happening in other models as well. I was under the impression that 10.1 fixed it.
