There's a bug in GUI on macOS version:
https://youtu.be/rwjMXxUurko
Vensim 10.1.1 macOS GUI Bug
- Test Model.zip
- (23.31 KiB) Downloaded 571 times
Re: Vensim 10.1.1 macOS GUI Bug
I think this is an instance of one we're working on ... seems to be random breakage of the GUI library. Are you using Sonoma or Ventura or another OS version?
If you download a slightly older version (10.0 or 10.1) it should be ok.
As Tom said, we are aware and are working hard to get to the bottom of the issue.
Thank you very much. Just wanted to make sure that such issues are not missed. Thanks again!
I've managed to get to the bottom of this issue (the compiler provided by Xcode has changed at some point since version 14.2 to introduce this problem, but conveniently, only in release builds).
A new build will be coming within in the next few days.
Hi there,
I'm glad it's working again on version 10.1.2 but just wanted to report and document this:
https://youtu.be/QPkKt69nBu8
We are working on it.
I've uploaded a fix for this.
Thank you very much, Tony! There's still a tiny issue with it, which I reported in the other thread.
