Lifecycle
hakani
Lifecycle
Post by hakani »
I am trying to develop system dynamic model about dairy cow lifecycle. Cow number growing exponentially but when calf grow , heifer should inceace , number of calf shoud be decreace. I'm adding model that I made.
I'm waiting for your suggestion
Thank you
dongu v1.mdl
(5.03 KiB) Downloaded 548 times
Re: Lifecycle
I'd start by adding units to all the variables in your model.
hakani
Re: Lifecycle
Post by hakani »
]Thank you i have added all to units
And i worked for control only 1 year
Result
hata 1.png (13.54 KiB) Viewed 14156 times
but it have to this
For example number of calf have to decrace later 6 mounts and number of heifer 6-12 have to increace
dongu v2.mdl
(5.16 KiB) Downloaded 396 times
Re: Lifecycle
I think your first step should be to adopt standard stock-flow notation in your diagram.
Currently you have no flows, so your are integrating earlier age categories directly into later age categories, like
Bull= INTEG (
    -Bull+"Bullock 12-18",
        0)
Units: number
"Bullock 12-18"= INTEG (
    "Bullock 6-12",
        0)
Units: number
This won't work, and produces the unit errors reported.
Re: Lifecycle
For inspiration, you might look to
C:\Users\Public\Vensim\Models\Sample\EXTRA\COMMOD.MDL
which installs with Vensim.
hakani
Re: Lifecycle
Post by hakani »
Thank you very much. i update to my model. i have 2 problem for now
1- i"d like first female calf and first male calf come about at 25 mounths but later other female and male calf come about once every 12 mounts.
2-Since the number of cows cannot be a number with a decimal(1,05 ), is there any way to solve this?
dongu akis v3.mdl
(10.59 KiB) Downloaded 413 times
Re: Lifecycle
1 - the PULSE TRAIN function might work
2 - you can solve this, but it may not be the best choice - https://metasd.com/2017/01/forrester-on ... ous-flows/
hakani
Re: Lifecycle
Post by hakani »
i set up my dynamic system with yearly units.
but first move time will be 26 mounth so i have to fix units ?
when i use time private variate , how can l use formula?
hakani
Re: Lifecycle
Post by hakani »
(Cow*Birth Rate)-(Cow*Death Birth Rate)-(Cow*Female Birth Rate)
how is formula for work above formula ?
So if time is 26< dont work
if time =26 formula work and it will work every 12 month ?
i did not solve
