writing text withe the Venapps tool
I tried to write a very simple text with paragraphs.
Being not able to copy the text on the textonly venapp control, i was obliged to suppress the paragraphs.
Joined a word file with the text with the paragraphs and without paragraphs.
After that to obtain a text with pargrpahs i have found two ways to do it.
The first adding blank spaces accordingly to the text and the second by adding a textonly control for each line which seems more practical.
Is there a more simple way to do that?
Joined the word file projet and the two .vcd files
Best regards.
essai8.vcd
(1 KiB) Downloaded 281 times
essai7.vcd
(1.14 KiB) Downloaded 285 times
Projet.docx
(10.39 KiB) Downloaded 309 times
Re: writing text withe the Venapps tool
Sorry, I do not know what you are asking for help with.
Venapps are not very flexible, all you can really do is add textonly for each line of the paragraph.
I do not agree with you.
You write:
'all you can really do is adding textonly for each line of the paragraph.'
I do not know if you have read the two solutions that I have exposed: one is with a textonly for each line as you propose but the other one is with only one textonly for the whole text with 8 lines.
With the new GUI, with the text input output objects, you can easily write a text with the paragraphs as you wish them to be formatted.
I just wanted to know if there is with the Venapps a same possibility.
