Get data xls with multiple subscripts
thifei
Post by thifei »
Is it possible to import data as in this exemple http://www.vensim.com/documentation/fn_ ... _data.html, but with multiple subscripts?
I only manage to import with one subscript.
Reffering to this example, is it possible to import all values from B5 to B10 directly in a variable Sales[shape,size] for instance, with autonomous differenciation of the shapes and the sizes?
thanks in advance!
Re: Get data xls with multiple subscripts
Can you get the sample models working? They should import more than 1 subscript.
thifei
Post by thifei »
I attached the files where I tried the example, can you tell me how to do pls?
imp multiple subscripts.xlsx
(9.2 KiB) Downloaded 392 times
GET XLS DATA test.mdl
(1.63 KiB) Downloaded 352 times
The GET DATA calls are basically 1-dimensional because the spreadsheet is 2D, and one is taken by time.
One possible way to semi-automate a GET call with more dimensions is to put the sheet names or first-cell references in a string variable with the appropriate subscripting.
In a case like this, importing the data to vdf would be less error-prone.
