Copy & Paste between models
I have a question, is there any way to do "Copy & Paste" between models that are in different files? Because I developed my model in several modules, each in different files, and now when I want to start integrating, I notice that I can't "Copy and Paste" what I've already developed. When I try to "Paste" in the target file, VENSIM doesn't paste anything.
Re: Copy & Paste between models
If you open them in the same application instance, this works. (If you open the files by double-clicking from the finder/explorer, you have two application instances, and it won't work.)
In pro/DSS, general settings, you can enable opening multiple models simultaneously.
When I open the another necesary model file in the same instance, the model that I have yet opened is replaced by the new open model.
What can I do?
What can I do?
You can only do this in Vensim Pro/DSS.
