Optimization with wrong subscripts error
When there are issues with the subscripts defined in the Vensim Optimization Control (.voc) file, Vensim reports 'ERROR: Problems encountered in the simulation.' when running the optimizer. It would be helpful if more targeted information is provided when this error is shown.
Thank you very much.
Re: Optimization with wrong subscripts error
Do you have an example you can provide? I can probably make changes very quickly.
Does this work?
New folder.zip
(13.65 KiB) Downloaded 377 times
I'll see if I can improve the error reporting. Maybe if I just change
ERROR: Cannot find constant in model
To one of the following depending on what is in the optimization control file.
ERROR: Constant not found in model, cannot continue.
or
ERROR: Constant found in model, but no subscripts in optimization control defined. Are subscripts missing?
or
ERROR: Constant found in model, subscripts appear to be incorrect. Are subscripts correctly defined?
Thanks a lot! It can also happen when subscripts are defined incorrectly.
