Help with PULSE TRAIN and random variable
Nub_User
Vensim version: PLE+
Post by Nub_User »
Dear experts,
I need model a variable that maintains a constant value (but obtained from a random variable) that lasts for 365 days and repeats periodically every 365 days.
What I want to simulate is a constant but random value every 365 days, and that the function keeps that value constant for 365 days.
I used a function based on PULSE TRAIN and RANDOM PINK NOISE, but I get a continuous random function while I need a discrete function lasting 365.
Could you please help me with that?
Thank you very much.
PULSE_test.mdl
(1.29 KiB) Downloaded 15 times
Re: Help with PULSE TRAIN and random variable
Try this instead ...
PULSE_test 2.mdl
(2.16 KiB) Downloaded 549 times
You can also use SAMPLE IF TRUE for this (though I think it's not available in all versions).
Nub_User
Post by Nub_User »
Thank you very much for the solution @tomfid!
Iam working with PLE+ version. SAMPLE IF TRUE is available in these version. Conceptually, how can I use it?
Nub_User
Post by Nub_User »
Thank you @administrator.
I read the syntax and help from the documentation Help. But I was referring to how the recommendation can be implemented for the specific problem I raised.
SAMPLE IF TRUE will hold a value until something is "true". So create a variable that equals 1 every 365 days, and use that in the call to SAMPLE IF TRUE.
Nub_User
Post by Nub_User »
thank you very much @Administrator :D
