I can't get a command script to work on macOS 14.4.1 with VensimDSS 10.1.2.
[code]
SPECIAL>NOINTERACTION
#SPECIAL>LOADMODEL|model.mdl
MENU>VDF2XLSX|BAU.vdfx|BAU.xlsx|SaveListForGraphs.lst
MENU>EXIT
[/code]
The command script, the MDL, LST, and VDFX are all in the same directory. I've made sure there aren't spaces and tried different locations on my disk. You can see I've tried with and without LOADMODEL (since I don't need to run a model -- just trying to automate data export).
I get no feedback. Vensim opens and nothing happens. No files are created in the folder with CMD script.
I'm calling it from Terminal (and my code editor app, but I've tried both) with
[code]
open -a /Applications/VensimDSS.app Export-XLS.cmd
[/code]
(NOTE: The path to VensimDSS on the Vensim documentation website (https://vensim.com/documentation/25670.html) needs to be updated since Vensim isn't installed in a Vensim folder any more.)
CMD script macOS problem
Re: CMD script macOS problem
What happens if you turn off
This fires up the command script successfully for me (run from a terminal prompt)
/Applications/VensimDSS.app/Contents/MacOS/VensimDSS /Users/tony/Downloads/TravisForumProblem/SampleCMDScript.cmd
Ah, that is definitely a different way at calling the script. I shouldn't use the "open -a..." command from Terminal. Just call the Vensim binary directly with "/Applications/VensimDSS.app/Contents/MacOS/VensimDSS".
I got my first script to work now.
Please update the documentation to help the next person.
Thanks for the help!
Quick aside: Is there a way to comment a line in a CMD file? I tried # but that gave an error. I don't see any comments in the examples.
Also, if I remember it correctly, ''MENU>EXIT'' does not exist on macOS.
Yeah, I'm not getting Vensim to quit/close at the end of my script, so I think MENU>EXIT is not working.
