Hi.
I want to pulish a model on the web.
in the documentation about downloading python there is only the 32 bit version mentioned. But one must download the 32 or 64 bit python installer?
Best regards.
downloading 32 or 64 bit Python version for web publishing
Re: downloading 32 àr 64 vit Python version for web publishing
I don't think it actually matters. During development we used the 32 bit version, but I'm sure 64 bit will work fine too.
Re: downloading 32 or 64 bit Python version for web publishing
But when I load the 64 bit versions it does not ask me to tick the path button.
I have downloade the 32 bit version and it works ok.
All the web files are there.
But if I run the webserver python file it writes 'port 8080' and stops there?
But the message is at the end the HTML file. Maybe if the message is written, it means that the test is positive? But it should logically return to the prompt?
