Setting Auxiliary With Lookup
dimasaaps
Newbie
Vensim version: PLE+
Post by dimasaaps »
Bagaimana Mengatur Input data untuk Variabel "Jumlah Pekerja Aktif" dengan Type Auxiliary dengan Lookup jika data saya Time Series di Excel yang telah di hubungkan dengan variable lain yaitu "Lowongan Kerja"
Bantu saya Setting
Translation (via Google).
How to Set Input Data for the Variable "Number of Active Workers" with Auxiliary Type with Lookup if my data is Time Series in Excel which has been connected to another variable, namely "Job Vacancies"
Cuplikan layar 2024-09-03 101601.png (164.72 KiB) Viewed 1938 times
Cuplikan layar 2024-09-03 101549.png (97.45 KiB) Viewed 1938 times
Re: Setting Auxiliary With Lookup
I'm not sure if you need a lookup.
Can you explain the relationship between "Vacancies" and "number of active workers"?
Not sure exactly what you're trying to do here, but if you want your data in a lookup linked from Excel with GET ... LOOKUPS, you can't use WITH LOOKUP. You'd have to use a regular lookup.
https://www.vensim.com/documentation/lookups.html
https://vensim.com/video/#Lookup_Tables
