i join a models with a run. The non custom graph at the top of the screen is correct and does not correpond to the custom graph below that does not correspond to the custom graph when one wants to edit it. In particular, the custom graph on the main screen has a minimum of 0 in contradiction with the minimum set in the cusom graph when one edits it.
problem with a custom graph
- current.vdfx
- (4.81 KiB) Downloaded 93 times
- Stay employee.mdl
- (2.81 KiB) Downloaded 101 times
Re: problem with a custom graph
If I switch to the old gui, it works correctly
Sorry, I cannot see anything wrong with these graphs. Can you provide more details on what is incorrect?
I have fçund a way to avoid partially the problem. I increase the height of the custom graph, But it still does not show the value of the lowest line of the graph as it is shown with the oldest Guy.
