subscripts
tsitsibangira
subscripts
Post by tsitsibangira »
How do I delete the SONGWE and MALI subscripts such that I can only work with INKOMATI in all the equations of the models (see the attached file). Am using VENSIM PRO.
Re: subscripts
Do delete subscript elements, click the "Edit range" button. The equation editor will be displayed, you can delete them from there.
tsitsibangira
Re: subscripts
Thanks. How do I delete the associated variables that are linked with the deleted subranges? Once I delete the subranges I got errors associated with deleted subranges.
tsibbie
Re: subscripts
Can you upload the model? Impossible to help without seeing the errors and the equations that include them.
Re: subscripts
Sometimes it's easier to do this kind of thing in the text editor, because you can search for the offending strings and then manually delete the associated variables or elements.
