Hi everyone,
I’m working on a Vensim model where I’ve repeated the same structure (containing 25 variables) seven times. Each structure has identical architecture, but the variables have distinct names for each repetition.
When I copy-pasted the structure, Vensim automatically renamed the variables by appending an ascending number to their names. Now, I need to rename these variables to match the specific naming conventions I’m using for each structure.
My question is:
Is there a more practical way to rename variables in Vensim without manually double-clicking each variable in the sketch view and editing them with the mouse and keyboard? I’d like to avoid repetitive and time-consuming manual work.
Thanks in advance for your help!
Practical Way to Rename Variables after Copy-Pasting Structures?
Re: Practical Way to Rename Variables after Copy-Pasting Structures?
You can replace the numerical sequence with a manually defined suffix when pasting the variables, if this is what you want.
If you are replicating seven times, using subscripts/arrays (only in Vensim Pro/DSS) would probably be better.
Is there a way to edit the names of variables pasted from a list, a text file, or a similar method?
Not easily. You can edit the MDL file in a text editor, but you would need to do a find/replace all.
