Blurred view and max/min
SteveVijayan
Vensim version: PLE+
Post by SteveVijayan »
I downloaded the latest version (10.2?) of PLE for my dissertation to my new PC (Windows).
I see that the equation editor is blurred. Is that normal? Or is it because of my PC?
Also, the max and min functions are resulting in errors when more than two values are used.
I had asked the same question before and Tom mentioned that the new version should fix it.
Please advise.
Thanks,
Steve
Re: Blurred view and max/min
It should not be blurry. Any chance you're using Remote Desktop?
I don't recall the status, but the variable-argument min/max may be in forthcoming 10.3, not 10.2.
SteveVijayan
Okay. Thanks.
I have attached a snapshot of the blur problem.
Thanks,
Steve
Blurred font in equation editor.png (113.8 KiB) Viewed 13292 times
SteveVijayan
Forgot to mention, I am not using remote desktop.
The file is in the pc.
Steve
Looks like a font problem. You could try changing fonts in Tools>Options>Fonts.
SteveVijayan
Okay, thanks.
Definitely a font issue. Try courier new or segoe ui.
SteveVijayan
Thanks.
I tried Vensim on my iMac.
There it looks clear and normal.
Steve
devM5
Post by devM5 »
My colleague recently found out that this is related to different display scaling settings (125%, 150% etc.) in a multi monitor setup. If I understood correctly, it behaves like that:
1. model opened on display A (lets say a 4k monitor set to 150% scaling)
2. Vensim window is dragged to display B (Full HD Monitor with 100% scaling)
3. equation editor will still open on monitor A since the model was opened here initially, but will now downscale the opened popup.
