I remember there is something non-obvious in loading an image.bmp into a model comment, but can't recall specifically what.
When I save a file image.bmp, and import from the comment dialogue box, an error that Vensim cannot import the image is returned. Maybe it's a file size issue? Any other clues?
Thank you
Sarah
bmp image file in comments
- Vensim version: PRO
Re: bmp image file in comments
The latest version of Vensim, you can either paste an image directly onto the sketch, or select "File" in the comment editor, and select the image you want using the drop down box beside it.
- Image1.jpg (89.55 KiB) Viewed 3533 times
