Reading in time series or constants
MarvinK
Post by MarvinK »
Hello everyone,
I am looking for an elegant way to use a slider in a very extensive model to decide whether time series (“GET XLS DATA...”) or only constant (average) values (“GET XLS CONSTANTS...”) should be read in from the same EXCEL file. I thought this would be very helpful for calibration, testing, and analyses.
My spontaneous idea was to use an IF THEN ELSE function to check whether a slider or the variable behind it has the value 0 or 1. However, the “GET...” functions “cannot include other expressions”.
I could define two more constants for each parameter, in each of which a time series or a constant value is read in. I could then use an IF THEN ELSE function in the actual parameter. If I do the whole thing via shadow variables, the diagram would also remain clear. However, the model consists of several sub-models with quite a few parameters. The effort would therefore be very, very high.
Does anyone have another solution? I would appreciate any tips!
Best wishes from Germany,
Marvin
Re: Reading in time series or constants
This won't work due to different variable types. However, you could read both and put the IF statement downstream, like:
x = GET XLS CONSTANTS(...)
y = GET XLS DATA(...)
x or y = IF THEN ELSE( slider, x, y )
MarvinK
Post by MarvinK »
Thank you for your feedback.
Does that pick up on what I had outlined? So, are you suggesting creating variables “x” and “y” and then using an IF THEN ELSE function in the parameter itself?
Correct.
The effort shouldn't be too much. One possible trick would be to implement this via copy-paste in the text editor.
For example, if you currently have
paramX = 123
you can replace it with the pattern I suggested above
x = GET XLS CONSTANTS(...) ~ unit ~ doc |
y = GET XLS DATA(...) ~ unit ~ doc |
paramX = IF THEN ELSE( slider, x, y ) ~ unit ~ doc |
