Sensitivity Analysis stuck after Cancelling
I was running a sensitivity analysis through CMD and noticed that I had a CIN file set in the simulation configuration. Vensim got stuck when I clicked on cancel (the animation is still running and the OS doesn't say that Vensim is not responding). Just waned to let you know. Here's the CMD:
SPECIAL>NOINTERACTION
SIMULATE>RUNNAME|Sens_v01
MENU>RUN_SENSITIVITY|o
MENU>SENS2FILE|Sens_v01.vdfx|Sens_v01.tab|*#
I used it by opening it from within Vensim. I think it should be replicated using any model.
Screenshot 2025-03-07 at 4.22.37 PM.png (1.02 MiB) Viewed 4207 times
Re: Sensitivity Analysis stuck after Cancelling
I *think* this is fixed in forthcoming 10.3, but I'll double-check.
Thank you so much, Tom.
ok, I tried this on Windows, it fails as no VSC/savelist are provided.
If you can zip the model and files needed to run this and email them to us (vensim@vensim.com), we can take a closer look.
Thanks Tony. Very much appreciated. I've attached the model here:
viewtopic.php?t=8471
