I want to develop a Venapp to create a user interface so stakeholders can use my model to test out different policies. I use the PLE version.
However, I don't really understand the Vensim Help and I don't understand how to start. I tried to find the Vensim Demonstration Disk Venapp. I looked on my computer but when I look under Program Files\Vensim I don't see models\sample\intro.vcd. I have been able to find the DEFAULT2.VTS there. Do I just open that with a text editor tool? But then how do I choose the different venapp files to edit?
Does anyone have some additional tips on how to get started?
Thank you in advance!
Venapp - simulation model interface
Re: Venapp - simulation model interface
If you are using PLE, your only option for an interface is to use SD Everywhere or Forio.
You can also build a simple interface on the diagram, without any additional tools.
The only option within Vensim is the DSS version. Is that correct?Administrator wrote: ↑Fri Mar 14, 2025 9:30 am If you are using PLE, your only option for an interface is to use SD Everywhere or Forio.
