Hi. What is the equivalent of this action in the command script? FYI, I want to run MCMC with the values obtained from Powell. Thanks so much in advance!
How to load '.out' using script command
Re: How to load '.out' using script command
You need the SIMULATE>ADDCIN command.
I could run it. Thank you so much!!
I have another question. Is it possible to tell 'SIMULATE>ADDCIN' command to read the .out file from a subdirectory rather than the parent directory where the model and .cmd files are saved? If so, could you please provide an example? Thanks again!
