System Dynamics Applications in Power Plant Steam Cycles
Locked
"Ray on EV1"
Post by "Ray on EV1" »
David,
System Dynamics may help you study a system with dynamics, that is a system
with stocks and flows, but your condensers normal mode of operation is more
than likely in steady state. As such, all relationships can be dealt with
algebraically. While SD tools are great at managing complex relationships,
your base problem may fall more suitably with more direct approaches.
Of course, the key to your systems performance may end up being management
around transient conditions and not steady state.
Ray
Dave Exelby
Post by Dave Exelby »
We have conducted several consulting projects using SD within a power
engineering context. These involved developing business cases for CCGT
plants and gas turbine development strategies. Both of these focused through
life costs (and value). The latter focussed on links between
· Impact of GT Technology Improvements
· Component Part Lifetimes
· Clean GT Performance
· Degradation of GT Performance
· Impact of Maintenance Philosophies
· Frequency of Maintenance
· Depth of Maintenance
· Customer/External Demand Drivers
· Demand Profiles
· Tariff Profiles
· Fuel Pricing
The strength of the approach was to link
engineering/operations/maintenance/demand planning within a high level
model.
Detailed engineering models can act as feeder models providing performance
curve data etc. Many such engineering models of course exist. Working in
the UK coal industry several years ago we used in house simulation models as
well as commercial packages such as AspenTech and GTPro. At the time these
performed steady state solutions although AspenTech has a dynamic package
now. These have detailed "in built" functionality to represent phase
information, steam tables etc. Phase information can be represented within
SD with a series of co flow structures for composition, temperature,
pressure etc. However, all this needs to be built from scratch within the
SD environment.
I would imagine that detailed engineering models providing data supporting a
high level plant dynamic model looking at demand side issues, maintenance
etc, to gain insight into long term performance and value would be a
candidate route.
Hope this provides some food for thought. You can contact me directly if
you would like more information
Dave Exelby
Dave.Exelby@hvr-csl.co.uk>
HVR Consulting Services Ltd
Locked
