Cycle Time
Cycle Time
Can Vensim return elapsed time taken for items to travel through a defined route in a the structure? This is needed to capture the actual leadtime for customers to undergo transistion form one state (level) to another. Please advise?
Depneds on wether you are looking at discrete items flowing through or a contimuous stream. For the former you could use a couple of simple SAMPLE IF TRUE on the entry and exit rates to log the times in the stock. If the former, try setting the stock up as a FIFO Queue, there are then associated Vensim functions for deriving thinds such as Average time in Queue.
