I found something else. The reform and clean command hada nasty side effect (see other initial problem thread). It caused all my lookups with "get xls lookups" to reduce to two pairs of numbers, like: (x,xxe-44,x,xxe-44).
I have vensim dds 32 version 5.1a. I tried it in an isolated model and the same problem occured. Is there any solution, or patch to solve this problem?
Jeroen
[Edited on 29-4-2004 by Pruyn]
Reform and Clean problems
Sorry for the double post, meant to add the following files to it.
- Initial Problem.mdl
- (7.53 KiB) Downloaded 674 times
I cannot reproduce the error here (but I am using 5.3).
When did you buy your licence, you might be able to get a free upgrade, visit http://www.vensim.com/download.html.
