I am running a model and there is a variable wich I need to change for different runs. It takes a lot of time changing this variable, running the model and repeating the operation for a new value. Has any one tried to automate this type of operation using Vensim PLE Pus?
Please any hints very much appreciated.
running batch jobs
You can try command scripts
http://www.vensim.com/documentation/html/25670.htm
Not sure if they work in PLE Plus though.
Maybe put the data in Excel, change there and run, that will be faster than editing an equation to change a data value.
[Edited on 8-8-2004 by Administrator]
