Venapp with 2 same WORKBENCH>Graph...
Deel
Post by Deel »
Dear All,
I´d like to compare 2 WB variable on the same screen on two WORKBENCH>Graph (eg.: "Var1" on the left graph, "Var2" on the right graph) the problem is: when i want to select "Var1" suddenly (because of shift to screen.) both graph will show "Var1" and vica versa.
how can i isolate or separate the constant selection method for both graph on the same VENAPP screen?
thank you!
Lajos
I think you need to set up two copies of the "Graph" tool in your toolset (call them graph1 and graph2). Then show graph1 in one window and graph2 in the other.
Deel
Post by Deel »
Thank you,
yes i already have a couple graph tool settings, but how to show all of them on the same VENAPP screen with different variables? i don´t know...
Lajos
Just put in a command control with a command SPECIAL>SETWBITEM just before the TOOL control for the graph - you will need to edit the complete control list or view as text to get the control order correct.
Deel
Post by Deel »
Thank you Bob!
Great idea!
it works.
Lajos
