Scaling issue
PhilippeG
Scaling issue
Post by PhilippeG »
I am using Vensim PLE Plus for Windows (xp) version 5.4 d with a very simple model where I repeatedly input 30 mg of a substance in a "body". I made no scale change. At the first iteration, where I should have 30 mg in the body, I only get 0.3 on the y axis of the resulting graph. I looked in this forum, I checked my model a number of times, redrew it completely and get the same result. Can anybody help me with this? It (I) appear(s) so stupid!
Many thanks for your help.:o
Scaling problem
Can you just send your model or a model simplified. Il will be easier to spot the problem.
J.J. Laublé
At a guess you are assuming difference equations, but have set TIME STEP to a number less than 1. If you want to do difference equations set time step to 1 - but it is better to conceptualize as a differential equation in which case rates are derivatives of the levels - so a rate of 30 mg/second causes the level to incrase with a slope of 30 mg/second.
If you put in units and do units checking things may become clearer.
PhilippeG
Post by PhilippeG »
Many thanks to both Bob and Jean-Jacques for their very usefull answers both on- and off-line
