I'm using the minimal dll. The problem that I have is when I try to register the dll.
What I'm doing is in Start>Run> I type the command: regsvr32 vendlm32.dll, and the dll file is in the folder c:/windows/system32
After run that command I get an error message: "Vendlm32 was loaded, but the DllRegisterServer entry point was not found"
Are those the correct steps to use the dll?
** Note: I copy & paste the vendlm32.dll that I have been installed from the CD in my computer, in other computer that doesn't have Vensim. And I tested it in two different machines (win xp and win nt) and I get the same error.
thanks in advance!
Dll register
