Listing all equations
thommy
Newbie
Post by thommy »
After I have entered an equation for every variable in a stick-and-flow diagram, how can make a list of all equations? Such lists appear in the vensim help topics but I 'm not able to find out how they are actually generated.
thommy
You need to use the documentor tool.
See
http://www.vensim.com/documentation/html/20150.htm
for more details. If you right click on the tool, you can configure what is shown by the tool.
Hope this helps,
Lee Jones
Post by Lee Jones »
Or you could go to the menu option View>As Text
jbh
Post by jbh »
Along the same wavelength of Thommy's post, is it possible to view a causes tree for an entire model?
Thanks,
jbh
You can change the depth of the causes tree by right clicking on the causes tool. You can select a depth ot 999. For small models this will give you the entire model and it will probably be useable. For big models it will just be a big mess and likely missing something.
jbh
Post by jbh »
Thanks Bob. I'm currently using the PLE version and it doesn't look like this will work. We have DSS on order. It should be here soon.
Thanks again,
jbh
