seasonal variation
seasonal variation
Could anyone please help me with the problem?
I want to build a model based on year, but with seasonal variation. Would vensim be possible to implement the idea and how?
Hope my explanation below would be clear.
I want to build a model whose time unit is year for simulating capacity addition and production. Because demand varys a lot by season, including seasonal variation for demand is prefered. In this case, monthly production and capacity utilisation can also be learned.
I tried to do it by using month as time unit, but am not sure if I did it correctly. Could you please have a look at the attached file and give me some feedback?
- demand example.mdl
- (2.25 KiB) Downloaded 1420 times
You are using a sensible approach (switch time to Month). Of course, it is a good idea to include units for everything - you can rename use
month counter/Unit time
as the input to the Lookup where
unit time = 1 ~ Month ~|
If you switch time to month do note that you have growth rate at 5%/month - not a bad business to be in.
If you want to keep time in years use
Month Counter = MODULO* (Time - Initial Time) * Month Per year, Month Per year) ~ Month|
Month Per Year = 12 ~ Month|
Bob eberlein
Bob eberlein
If you are running a monthly model I would recommend that you use time in Months setting time step to 1 or a smaller value if appropriate. To display graphs on years use a TIME BASE variable.
As far as cumulating things over years - there are no built in functions for this so you need to do things like
annual revenue = SAMPLE IF TRUE(MODULO(Time,Months per Year) = 0,cuming annual revenue,0) ~ $
cumming annual revenue = cum annual revenue + revenue * TIME STEP ~$
cum annual revenue = INTEG(IF THEN ELSE(MODULO(Time,Months per yer) = 0,-cum annual revenue/TIME STEP,0) + revenue,0) ~$
If you are into difference equations - as I am assuming you are - these are the kinds of tricks necessary. If you have a continuous view of the world then
annual revenue = MONTHS PER YEAR*smooth(Revenue,MONTHS PER YEAR) ~$/Year
time is in months for these.
Hi Bob, I tried to use your examples for calculating annual demand, but get the warning messags. what do these two messages mean?
annual demand = SAMPLE IF TRUE(MODULO(Time,Months per Year) = 0,cuming annual demand,0) ~ $
cumming annual demand = cum annual demand + demand * TIME STEP ~$
cum annual demand = INTEG(IF THEN ELSE(MODULO(Time,Months per yer) = 0,-cum annual demand/TIME STEP,0) + demand,0) ~$
WARNING: ACTIVE INITIAL differences found. Use Options>Setting to control reporting.
WARNING: -annual demand 1- Initial=0 Active=925685 has changed in value.
the warnings indicate that the time 0 computation for annual demand has changed from the value used to initialize other variables. You can use
SAMPLE IF TRU(MODULO(time,months per year) = 0 :AND: Time > INITIAL TIME ...
alternatively iniitlize it to a different value if that is important - this can get complicated as you may need to do things to avoid simultaneous initial conditions.
hello again,
my result of annual demand always stay 0 or the number i put in the equation in this case, but i could not figure out what the problems is.
what is the difference between sample in true and if then else?
the examples about sample if true in the manual are not helpful.
max workforce = SAMPLE IF TRUE(Workforce > max workforce,
workforce,workforce)
starting cash = SAMPLE IF TRUE(MODULO(Time,12) <.5, cash, cash)
SAMPLE IF TRUE is a dynamic function - like a level it changes only over time, but unlike a level it jumps whenever the condition is true rather than integrating its inputs.
If it never changes probably your condition is never true - if you are using years with a time step of 1/12 you should use the formualtion
MODULO(Time,Unit Year) < TIME STEP/2
if you use
MODULO(Time,Unit Year) = 0
it will never be true because 1/12 is not a power of 1/2.
if you use
I managed to have seasonal variation in a model which unit of time is year. However, I am confused by another question.
Please have a look at the attached file and tell me if it is correctly to know how many labors are required every month by dividing monthly demand by working hour. Shoud the working hour be 120 hours/month or 2080hours/year in this case?
- example.mdl
- (1.88 KiB) Downloaded 1211 times
seasonal variation
Joined a model with the right units and equations.
There is no link from the level to the rate.
I do not know if you have more then Vensim P.L. it should be readable in that version.
Pay attention to the units.
J.J. Laublé
J.J. Laublé
- example2.mdl
- (3.06 KiB) Downloaded 1036 times
seasonal variation
a small bug in the example2.mdl
joined the new version example3
- example3.mdl
- (3.04 KiB) Downloaded 1260 times
Thanks for joining the discussion.
The units of time in example 2 and example 3 are month, not year. Please have a look at the attached file. What I want is a model with year as unit of time, but have home seasonal variation on demand to result in different labor or capacity required. What I am confuesd is the time unit of variables after the part of total labor cost, such as total production cost, price, etcs. Hope you are not confused by me. Please tell me know if I am doing correctly.
- example4.mdl
- (4.36 KiB) Downloaded 1224 times
seasonal variation
I have made a small change, so that the lokkups has 12 values instead of 13, and the month counter is right and goes from 1 to 12, instead from 0 to 11.
Now the real problem is about the loop labor required, total labor cost, total production cost, that is not clear.
If the demand is increasing, the total cost is increasing but not the single cost of a widget. That cost as stated is stable
in the time, and I do not see the justification of the influence of the demand on price through this loop.
Secondly, what sort of inflence has the demand on price with the second loop, using the shadow variable monthly demand?
Is it the fact that the demand increasing and causing a shortage, the price can be increased?
Things need to be more clear to my opinion before getting on.
J.J. Laublé
J.J. Laublé
- example5.mdl
- (4.41 KiB) Downloaded 1510 times
Thanks for the prompt reply.
The example model is just a rough idea, and I will post the more detailed one when it is improved.
Currently, what I want to know from the example model is if it is correct to say the time base for variables such as labor required and total labor cost becaomes month, rather than year, although the unit of time of the model is year and the time step is 0.01. Could I accumulated 1 unit of time, year, to know how much labor costs per year?
Hope my question is clear to be understood.
seasonal variations
Hi Sintef
I have never used until now the time base function.
I have looked at the definition, which is not very clear.
I have not found where it is well explained or in what model
example it is used.
The examples shown int the time base function do not explain even the usefulness of the notion and when to use it.
If your question is about time base function and time base variable, it is better to ask Bob or an administrator who know much better than me.
J.J. Laublé
example it is used.
J.J. Laublé
The TIME BASE function is used only for display. You do not need this to convert from an annual to a monthly number. Using a continuous formulation
monthly demand = annual demand / months per year
or
annual demand = monthly demand * months per year
This is what you need to do anytime you want to change units. It is generally best practice to put all times in the same units (ie choose year or choose month and stick to it). There are exceptions, but not doing so can easily lead to confusion.
I would recommend that you build you model with time units months. What you have called "Annual Demand" is not correctly named. It should be "Underlying Reference Demand." At a minimum you should look at the Molecules to understand the anchoring and adjustment concepts.
or
