I would like to set a simple subscript constant with 10 entries as a game variable. In the Vensim Tutorial manual I read on page 111 that "you can convert any Auxiliary, Rate or Constant into a Game variable". But if I click on the drop-down arrow on the lower variable type box in the equation editor, I get only the selection "Normal" and "Tabbet Array". This is also valid if the variable is a single valued constant (and not a subscripted constant). What do I wrong?
Rgards, Peter
subscript constant as game variable
