How could I delete a shadow variable without affecting its source variable? When I delete the first, the second is done too.
Thank you.
Monte
Shadow variable deletion
Use the magic wand tool to hide it.
I have always thought of "Shadow Variables" as purely graphical objects, you use them to help remove a lot of clutter from influence diagrams. So if you delete a shadow variable, you are not deleting/hiding a graphicl object , you are deleting the actual parameter.
Hope this helps.
Hope this helps.
