Taking Results Reading at a Point in Time
Gem
Post by Gem »
Hi there,
I'm wondering if anyone can help me with the following problem:
My model contains a variable called "In On-Aircraft Maintenance" and this variable calculates the number of aircraft that are in maintenance bays.
My model runs on time step 1 hour.
I would like to get the results from this variable to give me the number of aircraft in maintenance every 6 hours. So, at hour 6 I would like the number in maintenance at that point in time, then at hour 12, and so on...
Is there a way of doing this?
Many thanks.
Globally setting SAVEPER to 6 in the model set up will give results every 6 hours. Alternatively in a custom table you can specify the display interval and the same can be done with the table tool (not PLE/Plus) by right clicking on it and setting Print Every.
Of course you may be looking for something different - so ask again if simple display is not what you are asking about.
