I am using Vensim 5.5d. I have a complex use and cause diagram.
When I select a variable and click on Loops button. I get 'Too many (32766) loops - truncating to 8000' error. As my diagram is complex, I am expecting more than 30000 loops.
I want to see all loops and do not want them to be truncated to 8000 by vensim. Is it possible to view all loops in vensim?
too many loops
The software is right, when it says that there are too many loops for only one variable, at least to list them, because the model may still run correctly.
Anyhow, what is the interest to list them, because I would like to know the method you will follow to analyze all these loops!
Jean-Jacques Laublé
Jean-Jacques Laublé
why listing too many loops
Well, I have a small set of variables (filtering set). I will be picking only those loops that contains any variable from that small set. Also, I might take the loop length into account (possibly discarding too small or too length loops).
The software should give option to save loops in a text file, if it can not display all of them.
Jean-Jacques Laublé
too manay loops
Can you post your model, so we can all see what your model is looking like. Maybe we can help if we can see it.
model is confidential
The model I have created is confidential and can not be disclosed.
I would like to know if it is possible to view/save more than 30000 loops in Vensim?
How many loops will be considered good for a model having variables in range of 25-30?
Regards
Gursharn
Regards
Gursharn
Loops are sorted by length. I really can't imagine there is much information in loops that are as long as the 8001st loop is - the 8000 limit was put in because the output was not useable.
I would recommend that you analyze the loops that are reported, and let us know if you think having yet longer loops displayed would be helpful.
