I have been faced with the problem at some point in the past.
What happens is that the plumbing is drawn, the variables in, then it comes to equation entry time and problems occur.
All the relevant variables for an equation are entered through linking with arrows. The equation is of the type A*B/C. I click on A, which appears in the Variables view of the equation editor and in spite of the variable being there and in the model, get the Unable to find error. Any ideas on how to get rid of this error?
Unable to find error?
At a guess you are not having this problem with A, B or C but with a variable that has escaped characters, perhaps embedded quotation marks, within it. If you could give the exact name of the variable Vensim can't find as you entered it in the Sketch I might be able to shed some light on this. Also make sure you are using the most recent (5.6a) version of Vensim as this type of thing was a known problem in earlier releases.
