Table truncation
nikvyas
Table truncation
Post by nikvyas »
Hello all (Bob?)
I have set my time step to one hour and the time bound between 1 and 8760 (1 year) which I would have thought is reasonable. However, the table truncates at 8000 which is more than a little annoying if you want to analyse the results. Is there a way to increase the truncation cut-off?
TIA.
The table tool can only display 8000 time values. Depending on what you are trying to do you can:
1. Increase the saveper on the model or specify a print every in the table.
2. Make SAVEPER a dynamics variable and have it big for a while then go to 1 when you need detail.
3. Set the time bounds to look at just a section of time.
4. Export the results to look at elsewhere .
