when do i need to use time step in my model?
when i set up a model, i always fact the unit problems,
such as, if invetory is a level (case), customer demand is a Aux(case), and sales(case/day) is Min(inventory, customer demand), i will see the unit wrong message, How to figure it out?
attachment is my practice model.
hope someone can give me suggestion...
thank you
what does time step mean
- 1.mdl
- (1.74 KiB) Downloaded 432 times
time step
Another more appropriate model, deals with the time step and not the time delivery is the model 3 joined.
You should study the Vensim\models\guide\chapter3, where you find inventory models.
You can find too plenty of inventory in other models too.
- 3.mdl
- (1.64 KiB) Downloaded 424 times
Hi Sally,
sales rate=MIN(inventory, customer demand)/delivery time
is dimensionally inconsistent - demand is widget/month so that demand/deliverytime would be widgets/month/month which makes no sense. inventory/deliverytime converts the stock inventory to a flow. If you can work through a few chapters of a text book on system dynamics it will likely be very helpful.
